One as upgrade from Sub 37?
Posted: Mon Aug 23, 2021 1:12 am
by MaxFerency
I have a Sub 37 and love it. I'm considering at some point getting a One. Can the One do everything the Sub 37 can do sound and feature wise? Is there a point in keeping the Sub 37 instead of trading it in for the One?
Re: One as upgrade from Sub 37?
Posted: Mon Aug 23, 2021 4:18 pm
by till
First of all, the Moog One does not sound like a Sub 37. The oscillators and the filters (2 on the One) are different.
Posted: Mon Aug 23, 2021 4:48 pm
by MaxFerency
Ok, can you elaborate more? I guessing the Sub 37's oscillators are fatter since they don't have to worry about getting too muddy with polyphony that the One does?
Posted: Tue Aug 24, 2021 6:55 am
by Matthias Adloff
Hard to answer. The Sub37 is more direct, the filters seem to go a little further in all directions. IMHO, the Sub37 again is not as direct and "fast" as a Mini or a LittlePhatty, so it's not the best unit to compare.
Things you can definitely trade in for the ONE are cheaper units like Mother32. It will be replaced at 100%. THe Sub37 just at 90%, to tell a number.
Posted: Tue Aug 24, 2021 11:28 am
by MaxFerency
Ok, that makes sense. Its not just a question of features but sound. Monophonic (or duophonic) synths tend to have a more immediate or fatter sound since its only one or two notes where as the polys have to be a little thinner so that when you play chords they don't sound too muddy.
Posted: Fri Sep 10, 2021 1:14 pm
by Otto Dix
MaxFerency wrote: Tue Aug 24, 2021 11:28 am
I'm not so sure about this. If you have any possibilities to get close to an Oberheim OB-X, an OB-Xa or a Memorymoog wich is even fatter than OB's, it will change your opinion.
The Memorymoog is so fat that it always needs to be EQ'd to sit in a mix. Just try a single Oscillator in Mono mode to program a bass sound, it kills any Minimoog you know. Prophet 5 are also very fat (vintage and new models). Countless bass lines have been made on P5.
Now, Moog One is a different beast. You can program it fat as f... but it will always sit in the mix.
Posted: Mon Sep 13, 2021 12:17 pm
by MaxFerency
Interesting. I'll have to look closer at those.
