Model D osc. boards
Posted: Fri Apr 23, 2021 7:12 pm
by Tonecab
Greetings! I´m in middle of troubleshooting older model D with defective Osc 2. I have also fully functioning later model D, with ua726´s on osc board. Is it safe and possible, to try that later osc.board in the earlier unit, just by test means? I´ve seen few older Model D´s retrofitted with later osc.board, so I presume they are interchangeable.
Re: Model D osc. boards
Posted: Sun Apr 25, 2021 7:05 pm
by kendallhalbert
Please be advised that the range and scale trim pots are in different locations on the new versus old boards. They will not line up with the access holes on the back panel.
Posted: Sun Apr 25, 2021 7:58 pm
by Tonecab
I´m aware of that, I just want test if silent osc.2 is caused by osc.board or somewhere else. I was asking just is it safe to swap boards, or is there something else electronically involved swapping boards?
Posted: Mon Apr 26, 2021 4:02 pm
by kendallhalbert
I went the other way (old board in "newer" unit) with no issues (other than the back panel thing). I'm assuming the same for your scenario.
