What does the VCF AUD input do?
Posted: Tue Apr 06, 2021 2:44 am
by Dizzle
Subject says it all...
...and how do you use it? What do you plug into it? VCF output of Mother 32?
Re: What does the VCF AUD input do?
Posted: Tue Oct 19, 2021 6:42 am
by richardfrost
It quite simply allows you to feed in an audio signal to the Werkstatt filter, allowing you to use the luscious filter with another device.
The problem you will have is that, as supplied, Werkstatt does not allow you to disconnect it's own VCO from the signal into the filter so your external audio will be mixed in with that. There is a Mod for this you can find online which involves breaking Jumper 57 (I believe, better Google before taking any action) and putting a switch in place so you can disconnect the VCO as desired.
I have ordered the parts to make this Mod and there are Youtube videos available on this too.
Posted: Tue Feb 01, 2022 9:00 pm
by Dizzle
Thanks. Was wondering what that was for.
Posted: Tue Aug 30, 2022 3:11 am
by gr00veh0lmes
You can set the VCO to a square and reduce the PWM to silence the internal oscillator.
Posted: Tue Jul 01, 2025 12:09 pm
by zaphod betamax
^ Yes I was going to say you could silence the VCO with the pulsewidth trick.
