Page 1 of 2
Moog Delay Tips and Tricks
Posted: Thu Oct 05, 2006 9:57 pm
by StompboxMan
We could all post out tips and tricks we do with our Moog Delay.
If you put a Compressor with full volume and sustain in the loop of the Delay with Feedback 3, then turn on the Compressor you can start a feedback loop as your note or chord ends. Then turn off the Compressor to turn off the feedback loop. It's interesting going from 2 repeats to infinite repeats and back to 2 repeats without using a foot controller into Feedback.
Posted: Mon Oct 09, 2006 2:37 am
by godzilla
i like to put my sh101 through the delay while it's cv out controlls the feedback, you get nice sounds that shreek when you play high notes
Posted: Wed Oct 11, 2006 2:21 pm
by Suburban Bather
An Electroharmonix Bass Micro Synth in the delay loop is cool. As the delay gets weaker the Micro Synths behavior gets more interesting.
Posted: Wed Oct 11, 2006 4:13 pm
by latigid on
One of the first things I did with my CP-251 was to send an inverted envelope (from MF-101) to delay time, which decreased the pitch as the envelope opened (using moderate feedback). I then played with the lag generator on the env. signal to get some whacky delay bounces!
Posted: Wed Oct 11, 2006 4:20 pm
by latigid on
Sorry, a negative envelope decreases the delay time, which
increases/raises the pitch. I might try sending some env. signals from the Sherman...
Posted: Sun Oct 15, 2006 12:58 pm
by latigid on
latigid on wrote:I might try sending some env. signals from the Sherman...
Very, very cool envelope-controlled pitch shifting. It reminds me somewhat of a Boss PS-3 on slow pitch shift, but better.
Also, you can control feedback, of course. Send a negative envelope to a high feedback setting to "stop" the feedback when you play. Once again, endless possibilities. Thanks Moog!
Posted: Wed Oct 18, 2006 5:41 am
by asd
I like the compressor trick, too bad I don't have a compressor pedal...
I like to use the feedback and some pedals in the loop as an actual sound source on it's own to process with the rest of the mf's. There's a pot in the back that I've turned up so the pedal feedbacks more.
Nothing really groundbreaking, I haven't really explored putting it in a feedback loop with all the controls under voltage control from the other mf's though
Posted: Sat Oct 21, 2006 8:42 am
by redeyeflight
A MF-101 with the resonance set to almost self oscillate through a MF-104 feedback loop is a wonderful sound...not exactly what you might expect too! Sort of a liquid, underwater gurgle...very very unique!
Posted: Thu Nov 09, 2006 1:58 am
by bentropy
I don't have the delay, but I have a question:
Can you send CV through its audio path, to delay CV signals, e.g. echoing the envelope out from the mf-101, and then sending this delay-processed CV on to a CV input somewhere (e.g. 103's sweep control input)? Or will 'bad things' happen?
Can you use audio signals as modulators in Moogerland? This seems unlikely, but this is possible in Nord Modularland (I know its apples and oranges...but just thought I'd ask)
thanks,
bentropy
Posted: Tue Nov 14, 2006 12:07 pm
by asd
Bentropy,
I haven't messed around with delays and cv, but I know there's some other posts in the forum about people doing so without damaging their equipment. If you have the 251 you can always use the mixer to make sure that the voltage doesn't get out of hand. CV signals are just like audio signals except they're below the range of what we can hear so everything used to process audio can process cv and vice-versa.
Posted: Tue Nov 14, 2006 4:37 pm
by OysterRock
bentropy wrote:I don't have the delay, but I have a question:
thanks,
bentropy
One thing to keep in mind is the bandwidth of the delay. I don't know if the delayed audio output of 104z will pass a low frequency control voltage simply because the bandwidth of the BBD chips is finite and won't pass frequencies above (and maybe below) a certain amount.
hmmm...I have a 104z, I'll try it when I get a chance.
Posted: Tue Nov 14, 2006 7:30 pm
by theglyph
It would be interesting to try sending a short S & H signal through the delay to control the pitch of say the Voyager creating an arpeggiated type of pattern.
I've never thought of using the delay to process CV's!
Posted: Tue Nov 14, 2006 9:08 pm
by asd
Great point about the bandwidth. I hadn't thought about that at all.
Posted: Wed Nov 15, 2006 4:37 pm
by OysterRock
So I tried out running CVs through the 104z last night. After a bit of level adjusting you can actually get quite decent results with an LFO or envelope through the delay. There was a lot of waveform distortion and some seriously funky results with the envelope (I used the MF101's envelope, not an ADSR or anything yet). Not sure what is causing this, but the results were still very cool! Especially something like adjusting the frequency of a square LFO for some crazy ping-pong rhythmic CVs.
Posted: Mon Dec 04, 2006 5:36 pm
by bentropy
Yay! So with a CP you could attenuated the signal to bring it in range of a suitable CV. I'm quickly building a collection of Moogerfoogers a MF-101, 103, and a 102 on the way. Next a CP, and I want to get the delay but its a pretty penny. It would be really cool to be able to echo CVs, yeah like a env follower. Can you post some results if you have a chance?
thanx,
bntrpy
