Subharmonicon question
If I have a sequence running on my Subharmonicon but neither SEQ 1 ASSIGN nor SEQ 2 ASSIGN are set to their respective Osc/sub1/sub2 (ie I have not assigned any destination) should I still hear a note being played as the sequence advances? It seems wrong that I should hear anything but I do. Is my unit faulty?
Re: Subharmonicon question
Yes, the single filter and amp that is shared by all voices is triggered each time a step on either SEQ 1 or SEQ 2 is taken.
If you want to control when the envelopes are triggered, you can press the EG button so it switches off and then send a gate into TRIGGER when you want the envelopes to fire.
