Grandmother: Multi trig issue with the new firmware
Posted: Sat Sep 26, 2020 4:03 am
by le__rien
Hello,
I just updated the firmware of my Grandmother (it sounds very strange to write this...).
I activate the multi trig function following the instruction described in the firmware manual, but the multi trig seems to not work properly: the envelope does not rettrig each time I play a new note, it just follows the first cycle.
Does it work for you ?
Re: Grandmother: Multi trig issue with the new firmware
Posted: Sat Sep 26, 2020 10:42 am
by bichuelo
It works fine here, just as expected.
Did you make sure you use the F#2 and A#1 to select the parameter, and press twice G0 to set it to on?
Posted: Tue Sep 29, 2020 5:20 am
by andybutler
Working fine here.
Possibly there is some confusion.
Retrigger will not cause the Attack phase to restart.
(This is a normal monosynth behaviour, as to suddenly chop down to zero with each note would have it's own adverse affect on playability)
To check the function, turn attack to zero, set short decay and drop sustain to zero.
