Subsequent 37 MIDI loop Issue
Posted: Fri May 15, 2020 10:46 pm
Hi, I’m having a problem with using the midi function on my Subsequent 37.
I keep getting stuck notes or rare but quick dropouts/detuning when playing or during return playback and keep having to hold the octave buttons to reset it (very annoying).
I’ve changed the midi in / out to different channels, turned off local control, and reinstalled the newest firmware (1.3.2) too many times to count.
I am using Logic Pro X with an Arturia Keylab 61 as the midi controller. In logic’s midi settings I’ve turned off or uncheck marked the midi ports for other devices highlighted in white being used (Saffire Pro40, Scarlet18i8)
Though there are around 1,000 or so unhighlighted devices for EZdrummer turned on (Have turned off or unchecked around 300 before getting tired. MAYBE the only thing left to try.) and still notes get stuck.
Very confused why this MIDI loop is happening still, unless it’s the 700 EZdrummers left to uncheck but I doubt it.
Any help or ideas would be fantastic, thanks!
