Matriarch output - is TS instrument cable OK?
Posted: Wed Apr 15, 2020 8:06 pm
Hi all! This may be a silly question but I'm hoping you can help me understand! I'm still learning about how some of this stuff works.
I've just bought a Matriarch and I'm loving it. The manual describes the line outputs on the back as BALANCED TRS. Is it okay to use UNBALANCED TS instrument cables here (like guitar cables)? I am running the line-outs of the Matriarch to two line-level +4db 1/4" inputs on the back of an RME Fireface UCX for recording into my DAW. The level on the interface is set to receive at +4db
Is this a healthy configuration? Do I NEED balanced TRS cables to get the appropriate signal, or will these TS instrument cables be sufficient to feed my interface line inputs? Do I have anything to gain by switching this to balanced inputs? I'm not running these cables at any length greater than 10 feet.
Thank you for your help! Any supplemental information about the electronics or what's going on technically would be appreciated as I learn more about how all this stuff works!
