Using Grandmother Seq/Arp on external synths
Tabletop Semi-Modular Analog Synthesizers
goldenavenger
Post by goldenavenger » Mon Sep 09, 2019 9:43 pm
Hi!
Can I use the Grandmother's Sequencer or Arpeggiator on an external synth (specifically the Sirin).
I will own both soon and I'm trying to figure out any ways that they can interact, and the absence of a sequencer on the Sirin bothers me. Does the Sirin software have a sequencer?
Any advice would be appreciated!
bichuelo
Re: Using Grandmother Seq/Arp on external synths
Post by bichuelo » Mon Oct 07, 2019 10:44 pm
Hi, and welcome to the forum!
Yes, you can use the Grandmother's sequencer with the Sirin with great results. And no, the Sirin's editor does not have a sequencer/arpeggiator. But you can achieve great results after you do a melody on a piano roll from your DAW to the Sirin, then send a sequence from the Grandmother using the CV outputs and remap them to different parameters
The results can be wild
http://audiotecna.info
bichuelo
Post by bichuelo » Mon Oct 07, 2019 10:58 pm
Well, actually the pitch calibration can be tricky on the Minitaur/Sirin to be honest. You can always build your melody on your DAW and reassign the pitch to another parameter and have a great time
misterpete
Post by misterpete » Tue Dec 24, 2019 2:22 am
Ive been using Sirin with Grandmother and LOVING it ~ Minitaur too
Right now SIRIN is paired to my Matriarch … great combination(s)
my Voyager XL is hooked up with my Slim Phatty, though it works great with Sirin and SOUNDS awesome paired with anything really however the Slim arp created a few Midi CC issues with the new Mother/Matriarch which I notified Moog about… Slim should have a setting to filter out all Midi except notes - doesn't it? the sync was screwed up and turning the glide or mod wheel activated Latch and Arp on the Slim (for example)
I will have to take a closer look … but i think either or both Slim & GM/M will require Firmware update to address that compatibility issue …but SIRIN does not have any issues with the newer instruments that i HAVE discovered yet
Please Call Me, PETE
"Mr. Pete" at MuffWiggler |@petedako on Twitter
