Sub37 Sequencer will not record new sequences
Posted: Wed Sep 04, 2019 3:28 pm
by Coolian
I just got a Sub 37, but having issues with the sequencer. Whenever I try to record a new sequence, nothing happens. By this i mean nothing is displayed in the LCD and no sequence of notes is emitted from the synth.
According to the manual and videos I have researched online, I am doing everything right. But the sequencer is never activated. It is worth mentioning that the sequencer does play for presets that have a sequencer associated with them, just not when I try to record my own sequencer.
Previous measures I have taken to resolve the issue were to install both versions of firmware, which unfortunately did not solve the problem
Re: Sub37 Sequencer will not record new sequences
Posted: Wed Sep 04, 2019 5:44 pm
by till
A quick test:
Disconnect alle cables except power and audio. No USB or MIDI cables.
Powercycle the Sub37.
Does this change the behavior?
If not, check if local control is on or off. It should be on with ON without USB and MIDI connected.
Posted: Thu Sep 05, 2019 2:19 am
by Coolian
Hi, I tried the above suggestions and the sequencer remains inactive..
Posted: Thu Sep 05, 2019 2:46 pm
by DrJustice
One thing that may be worth trying is to reset the system parameters:
GLOBAL MENU 3.3. -> INIT SETTINGS
Posted: Thu Sep 05, 2019 4:42 pm
by Coolian
Hi, also tried this an nothing..
Posted: Thu Sep 05, 2019 7:21 pm
by DrJustice
OK, so not external factors and no configuration strangneness.
It's not impossible that the REC position of the PATTERN switch isn't being recognized. You could try wiggling the switch a bit in the REC position, applying a little sideways force (not too much!).
Posted: Sat Sep 07, 2019 2:57 am
by Coolian
Thanks for the suggestion DrJustice. Though it seems the issue extends beyond the sequencer to the arp - no setting works on the dial but arp down.. seems like the guy who sold knew it was bunk and didn’t mention ..
Posted: Sat Sep 07, 2019 2:58 am
by Coolian
Probably looking at a costly and lengthy process to get the issue sorted here in Europe
Posted: Fri Nov 27, 2020 5:30 am
by Mantrak
Exactly the same thing just happened to me. The PATTERN knob plays dead, stuck in Up position. Any news with your Sub37? Have you managed to fix it?
Posted: Fri Dec 11, 2020 7:51 pm
by Bengoss
Any fix?
Mine just stopped working.
If I use the vst editor it works, but the pattern knob doesn’t do anything.
Ben
Posted: Sat Dec 12, 2020 5:13 pm
by Bengoss
Mantrak wrote: Fri Nov 27, 2020 5:30 am
Did you find a way to fix it?
Posted: Sun Dec 13, 2020 5:23 am
by Mantrak
No. I wonder whether this is a mechanical or electrical switch fault which I doubt, or a fault in the swith control circuit. At this point I am ruling out anything software related. Bummer
Posted: Mon Dec 14, 2020 11:57 am
by Bengoss
Mantrak wrote: Sun Dec 13, 2020 5:23 am
Thanks for your reply.
I did send a message to moog but still haven’t heard back from them.
It’s weird, it just stopped work suddenly, I haven’t moved the synth or anything.
It works with the vst editor though. That’s why I think it’s most likely a hardware issue.
Ben
Posted: Tue Mar 16, 2021 9:05 am
by Mantrak
Eventually I sent the synth to official Moog service shop, EMC in Germany. They fixed it by replacing the control board. By the way, I am highly recommending EMC, Stefan is the guy! Top quality service, as it should be for a top brand like Moog.
