Model D reissue pitch bend range via Sysex
davidrsimpson
Post by davidrsimpson » Tue Oct 09, 2018 11:56 am
I'm trying to change the pitch bend range of my Model D reissue via Sysex but I can't get it to take. Have I misunderstood this functionality? The Sysex I am sending is the following:
F0 04 15 00 14 05 00 0C F7
Any advice would be much appreciated!
Thanks.
Markyboard
Re: Model D reissue pitch bend range via Sysex
Post by Markyboard » Mon Oct 15, 2018 10:03 am
It looks like you're trying to set the pitch bend value to 12 decimal (0C Hex) which is the default. So no change. Try a different / lower value like 5 for example. Otherwise your message appears to be correct.
F0 04 15 00 14 05 00 05 F7
Minimooger
Post by Minimooger » Sat Oct 20, 2018 5:47 am
davidrsimpson wrote:Hi,
Thanks.
Be aware that this affects only the MIDI pitchbend . It does not change the actual pitchbend on the minimoog undless you use that additional board.
Markyboard
Post by Markyboard » Sun Oct 21, 2018 7:00 am
I didn't realize this (I have the original only). But being a re-issue this makes sense.
davidrsimpson
Post by davidrsimpson » Mon Oct 29, 2018 3:32 pm
Thanks guys, that's very helpful.
