LFO with upper & lower limits?
Posted: Wed Sep 05, 2018 10:02 am
Is it possible to run the LFO ( native on the Voyager, or with an external unit of some sort ) so that you have control over the upper and lower limits of the LFO sweep?
ie: right now the LFO runs in a cycle through it's full frequency range, and the only control you have is the speed
but if there were 2 other parameters you could adjust...being able to set the upper limit and lower limit of it's range, I think that would be incredibly useful
example: when using the LFO to drive the cutoff filter amount, you could set it to only run
1. the top portion of the sine wave
2. or only the bottom
3. or any range of defined upper/lower limit
a dedicated lower limit knob & upper limit knob would be great
Does anyone make anything like this, and could it be hooked up to the Voyager?
thanks!
thanks!
