DFAM Oscillators with M32
Posted: Mon Jan 22, 2018 11:06 am
by stewdio
Are the oscillators the same/similar between the two Mothers? I'm curious if adding a DFAM means I'd be able to make 3 osc patches on the M32 when I'm not using the DFAM for percussion sounds
thanks!
Re: DFAM Oscillators with M32
Posted: Mon Jan 22, 2018 1:25 pm
by stiiiiiiive
Just thinking out loud: to do that, you would need direct oscillators output on the DFAM. Does it have some?
Posted: Mon Jan 22, 2018 3:25 pm
by stewdio
stiiiiiiive wrote:Just thinking out loud: to do that, you would need direct oscillators output on the DFAM. Does it have some?
it appears so from this patch template:
https://www.moogmusic.com/sites/default ... te_Web.pdf
and my thinking is that I could blend the DFAM oscillators with the VC mixer on the 32, then take that mixed output into the external audio in...
Posted: Mon Jan 22, 2018 5:09 pm
by stiiiiiiive
Right, it appears so. Good news then :)
