How to Sync LFO Rate with an external clock
Posted: Sun Jan 21, 2018 4:00 pm
by samer
Hello,
I have a mother 32,
How to sync my LFO rate with an external clock?
I have Arturia Beat Step Pro or even from my Ableton clock.
Thank you
Re: How to Sync LFO Rate with an external clock
Posted: Tue Jan 23, 2018 3:26 pm
by yobink
MIDI to the mother 32 and then assignable output set to clock to LFO rate in should do it
Posted: Sun Jan 28, 2018 10:55 am
by samer
Thank you for the feedback, but the LFO rate is not getting insyc with my BeatStepPro clock.
I have changed the assignable output to the second option "CLOCK", I have also tried the other 2 clocks 3 and 4 and didn't work.
thanks,
samer
Posted: Wed Feb 07, 2018 12:37 pm
by conspiracytherapist
What kind of "sync" are you expecting? I believe analog LFO's are pretty limited in how they "sync" to a clock. The LFO's waveform will simply retrigger with each beat or bar. So, the actual rate is not in sync with your BPM, but the wave shape will restart on time—so mostly noticeable and useful with Square and S&H, maybe not so much with a triangle or sine.
From my Minimoog Voyager's manual:
...the LFO is an analog circuit, and does not automatically sync to MIDI clock; it is restarted much in the manner of oscillator sync, and does not defeat the Rate control.
Posted: Sat Mar 31, 2018 4:34 am
by ulverine
unfortunately the mothers assign out doesnt pass through the midi clock, only clock out when the seq is running.
which i'd really like to see adressed by a firmware update....
Posted: Thu Feb 16, 2023 1:35 pm
by solarj
Hey, old post but I just published a video where I cover in detail the issue of syncing the LFO with an external clock source on the Moog Grandmother.
Have a look
https://www.youtube.com/watch?v=7GM15i7BwbI
