minitaur no working with analog four CV GATE
Posted: Sun Jan 14, 2018 7:57 am
by cuca123
hi all guys. Can somebody please help me step by step how configure analog four with moog minitaur or moog minitaur with analog four via CV / GATE ? i can´t get any pitch. I have more cv synthesizers and they dont give problems, all except minitaur. I installed the latest firmware and have followed some instructions in other forums but no good results. its a nightmare, i use the calibration cv tool in the editor but its impossible to fix this problem.
i have note 1 > "c2" 1.000volts note 2 > "c5" > 4.000 volts pitch/oct
thanks and sorry for disturb.
Re: minitaur no working with analog four CV GATE
Posted: Tue Jan 16, 2018 1:51 pm
by SlowLFOtoPitch
**Minitaur Pitch CV Calibration Procedure**
- Connect the voltage source to the Minitaur's pitch CV input.
- Now connect the Minitaur to your computer via USB and open the Minitaur Editor.
- In the editor settings, locate the 1 volt and 4 volt calibration options.
- Send 1 volt signal from your voltage source into the Minitaur, then click the Pitch CV Calibration +1v button. You will see the MIDI light on the Minitaur blink.
- Send 4 volt signal from your voltage source into the Minitaur, then click the Pitch CV Calibration +4v button. You will see the MIDI light on the Minitaur blink.
- This ends the pitch CV calibration procedure. Please test with a 0-5v CV source.
If this does not correct the issue, please contact us directly and we will be more than happy to help.
Adam Pryor
adam@moogmusic.com‬‬
(828) 251-0090 Ext. 246
Harrison Street
harrison@moogmusic.com‬‬
Ext. 221
Noah Jolly
noah@moogmusic.com‬‬
Ext. 204
Thank you,
Taylor Mott
Service Manager
taylor@moogmusic.com‬‬
Ext. 217
Posted: Thu Jan 18, 2018 4:31 pm
by cuca123
thanks but it doesnt works .
