sub phatty Midi IN doesn't work perfectly
Posted: Tue Dec 19, 2017 6:31 pm
by Loïc
Hi everyone.
So here's the deal. my moog sub phatty doesn't respond to midi datats coming from my computer perfectly. Every other loop, he forgets an info. Such as a pitch bend or mudulation thing. I can't have it making a descent loop; like in always the same loop. Sometimes the pitch bend will not be done, sometimes the modulation value will stay at an unwanted value, and so on...
I just drew a very simple curve in ableton live, it doesn't work like it should. keeps modulating when it shouldn't, forgets to modulate when it should... (it's hooked up with midi cable, not USB)
any idea?
Re: sub phatty Midi IN doesn't work perfectly
Posted: Sun Mar 18, 2018 9:21 pm
by wave100
Not sure if this is the answer, but I think you have to have the modulation curve from Ableton at exactly the same level at the start and end of the loop otherwise there will be an offset each time you cycle round the loop.
Posted: Fri Mar 30, 2018 4:25 am
by Loïc
Actually, ableton wasn't able to send anything midi properly with my buffer set on 128. that even includes midi over USB sent in another synth. It seems the subphatty isn't at fault. Ableton is.
I got better results with my buffer rate set on 512.
Sorry guys, but my subphatty is working like a charm!
