Using my Sub 37 as midi controller works in Ableton except occasionally when I disarm the sub 37 and arm another instrument, the keys played will also trigger the same keys on my Sub 37. I noticed this problem is fixed when I turn off the Sub 37 and then back on. The Sub 37 is then only triggered when I arm the sub 37 in Ableton as expected. It seems to happen most often when I have another instrument armed and I adjust the filter or other knobs on the sub 37. I think it's a midi setting, just not sure which one.
Sub 37
in channel: 1
out channel: 1
send prg chg: on
rcv prg chg: on
in ports: both
out ports: both
echo din in: off
echo usb in: off
poly number: off
poly max: 3
Ableton
midi from
:all ins
:all channels
Monitor
:auto
Audio to
:master
External instrument
midi to
:moog sub 37
:channel 1
audio from
:2
Thanks for the help.
In Ableton, other instruments trigger Sub 37
Last bumped by ChrisA on Thu Dec 07, 2017 2:31 am.
