minitaur editor doesnt stick
sub guy
Post by sub guy » Thu Jul 27, 2017 12:51 am
When I use the editor to change settings on the Minitaur I lose the settings after powering down. Specifically velocity sensitivity. I am having to set it each time before playing it. Am I missing a function on the editor that makes the changes permanent?
SlowLFOtoPitch
Re: minitaur editor doesnt stick
Post by SlowLFOtoPitch » Thu Jul 27, 2017 8:21 am
Hi Sub Guy,
Did you save the preset you were working on? Velocity sensitivity in particular is stored per preset, so if the preset was not saved, neither were you changes.
Save Preset
Save Preset
Screen Shot 2017-07-27 at 8.20.09 AM.png (11.25 KiB) Viewed 2818 times
Hope this helps!
TAYLOR MOTT
SERVICE DEPARTMENT MANAGER
MOOG MUSIC INC.
P: (828) 251.0090 ext. (217)
Fax: (828) 254.6233
sub guy
Post by sub guy » Thu Jul 27, 2017 1:54 pm
SlowLFOtoPitch wrote:Hi Sub Guy,
Hope this helps!
It does help. I dont use presets so had not even looked into that part of the manual. Ill look into that this evening. Thanks.
