Hi to all,
I'm using my Minitaur in Ableton live 9 as external effect. It seems to work quite good but I have a problem: if I use the external effect plugin of Ableton 100% wet I'm hearing only noise, sweeps and pops. It seems that there is something wrong because in this video https://youtu.be/2Gm8BvxJrN8 (minute 1:44) with 100% wet effect the result is very cool.
Do you have any suggestions? Maybe the external effect plugin was updated and works in a different way now?
Many thanks for the help!
Luca
Minitaur and Ableton external effect
Re: Minitaur and Ableton external effect
Hi good news! I've solved the problem: it was a routing misconfiguration in the UAD console I'm using (the cue output was set to MIX and not on the right output channel). Now the Minitaur works exactly as the one in the Moog's Youtube video
