Assign mod wheel to pitch
Posted: Fri Mar 10, 2017 5:26 am
by Gbags
I'm wondering if it's possible to assign the mod wheel to pitch so I can drop the pitch of a sequence by exactly 2 steps without having to press a new key. Any advice would be much appreciated! Thanks!
Re: Assign mod wheel to pitch
Posted: Fri Mar 10, 2017 8:47 am
by DrJustice
Yes, that's possible, you'll have to use one of the two MOD sections:
- set the MOD SOURCE to F.EG / PGM
- push the CONTROLLERS button to open the MOD x CONTROL menu
- set MOD WHEEL to 100%.
- go to MOD x EDIT and set PGM SRC to CONST ON
- turn the PITCH AMT counter clockwise to get the desired pitch while the modwheel is fully engaged.
If you think the PITCH AMT is a bit abrupt, you can tweak the MOD WHEEL percentage in the third point above to get a comfortable range.
Posted: Wed Mar 15, 2017 11:55 pm
by Gbags
That worked perfectly. Thank you!
