Any other CV pitch correction device like Theremini's?
This is the place to share tips, tricks and questions about Moog's controller products; the MP-201 Multi-Pedal and the EP-2. There are a world of applications for these expression enhancers. Explore...
Joseph Merrill
Post by Joseph Merrill » Tue Mar 07, 2017 1:50 am
Hi all, first post
Moog Theremini has pitch correction allowing it to force your theremin playing onto a chosen key, with a percentage knob (0-100%). I chose instead the Moog Etherwave Plus for the two CV output so I don't have that feature. Is there a control device out there that can do what Theremini does to correct the pitch?
Thanks in advance!--Joseph
_DemonDan_
Re: Any other CV pitch correction device like Theremini's?
Post by _DemonDan_ » Tue Mar 07, 2017 11:17 am
Hi Joseph,
Obviously, this trick won't help your control voltages, but this is what it
sounds like when you pitch correct the audio out of an Etherwave:
https://www.youtube.com/watch?v=xCSP6pnbefk
(Starts at 7:20)
One easy way to get your Etherwave to control something else in a
chromatically-quantized way is to use a Pitch-to-MIDI converter (and then
ignore Pitch Bend messages).
Here's a cheap solution, but you can certainly find more feature-laden
Pitch-to-MIDI solutions as well:
https://www.youtube.com/watch?v=bWaNlcXuGmI
(Starts at 3:35)
rove
Post by rove » Wed Mar 08, 2017 12:58 am
If you have a modular system, a quantizer will do what you are looking for, there are many available, it takes a smooth voltage in and quantizes it to a chosen scale.
Joseph Merrill
Post by Joseph Merrill » Fri Mar 10, 2017 12:12 pm
Thanks for the help folks!
