Ring modulator stopped working after UK visit
Posted: Fri Mar 03, 2017 11:36 am
by Egesukaymak
Hello guys it's my first post here and I hope I can get some help.
I was at the UK this January and played couple of gigs. I tried to use my ring modulator on one of them. Plugged in via an adapter converter for U.K. plugs. Used the original adapter plus the plug converter. When plugged in lights came on but went off shortly after. Tried it again with another original moogerfooger adapter, same thing happened. Thought it was the adapter which has the problem. But I tried it again after coming back and now the pedal seems like it's on but there's no sound just a very noticeable hum. It blocks the guitars sound too. All I hear is a hum noise.
I also had my freqbox with me at U.K.too but not used it. Freqbox works perfectly fine. Did I somehow fried it because I ran it through a converter? If so what should I do to fix it? If no what could be the problem?
Thank you.
