MF Drive - Amperage
Posted: Sat Jan 07, 2017 6:25 pm
by signals_
What's the max amperage the MF Drive can handle? The web states 10mA; most bricks are around 500mA. Your help would be greatly appreciated.
signals_
Re: MF Drive - Amperage
Posted: Mon Jan 09, 2017 11:36 am
by _DemonDan_
signals_ wrote:What's the max amperage the MF Drive can handle?
Hi signals_,
I'm not an EE expert, but my understanding is that a device only pulls the amperage that it needs, regardless of how much is available. So it is only important that your power supply's amperage is rated higher than what you need.
I have many power supplies rated much higher than what the devices need.
EEs, please chime in if I'm wrong on this....
Posted: Mon Jan 09, 2017 12:44 pm
by signals_
Thanks for the response, Dan. I suspect you are correct but wanted to check to see if there were any quirks with the MF Drive. I'm no EE expert either
Posted: Mon Jan 09, 2017 3:57 pm
by stiiiiiiive
Not EE neither, but I second that
Posted: Wed Jan 11, 2017 12:22 am
by Gladmarr
_DemonDan_ wrote:signals_ wrote:What's the max amperage the MF Drive can handle?
Hi signals_,
I'm an EE, and you are correct about that. Unless the pedal breaks and draws more that the usual amount of current. But at that point all bets are off.
