sound is "going away" after a minute or so...
Posted: Fri Dec 02, 2016 4:54 pm
Hiho guys,
my sub37 gets quiter on headphone output from time to time slowly over a minute down to nothing. Sometime sit takes longer - sometimes the effect is not there. It seems get faster / more often if i twek filter or other "volume" related pots (except the "volume "Knobs for main and headphone out)
The sound of moving filters could be still heard - it seems just the oscillator sound is going "away" while the main audio out stays normal.
First i thought this must be a potentiometer problem on the headphone pot / jack, but it isn't - i could twek the main volume and headphone pot without any change of the effect (while the sound gets quiiter/louder as expected while tweaking the volume knobs, the "overall" volume is going down and the sound get's a bit more "hissy"). On a full analog synth with pots i would tip onto a cold soldering point, pot contact problem or so, but this would not reset each time after a system restart. i would It seems more a software related thing, because when i restart the sub37 hardly it works again. If i "just" switch presets it doesn't change (but may depend from the preset).
I know, this sounds crazy, but is ugly when fiddeling just on headphones. I hear the filter / gate but no osc, while on the main out the sound is fulle there (i thought headphone and main out are some kind of just "parallel").
Any idea? Software bug?
Will try to full reset the system and replay the firmware onto it (it is the latest 1.20/1.20).
Does anyone seen a similiar bug / effect?
many thanks,
Niels.
many thanks,
Niels.
