Sub 37 editor not recognizing moog anymore..
Posted: Sun Oct 09, 2016 12:53 am
by rumblenaut
It used to work just fine, until I tried today.
I re-installed the newest firmware , and the problem persists. It is connected Ableton's MIDI settings to, TRACK, SYNC, and REMOTE are enabled for the Moog sub 37's input and output.
The error reads "THE EDITOR CAN'T CONNECT TO THE HARDWARE, PLEASE SET MIDI IN AND OUT ON SETUP PAGE"
On my MIDI setting on the moog, it is set to Send/Receive on channel 1.
SEND PGM CHG/RCV PGM CHG are also set to ON.
Picture of my editor's setup page: http://imgur.com/a/7yfNQ
Picture of Ableton setup page: http://imgur.com/a/gkzxu
I just re-arranged my whole studio and bought a moogerfooger, so I may have accidentally changed or configured something wrong, but I have no idea what it could be other than the parameters I described above. :shock:
Re: Sub 37 editor not recognizing moog anymore..
Posted: Sun Oct 09, 2016 5:05 pm
by Novem808
You may want to connect the Sub via USB to you computer/audio interface directly, and open the editor in stand alone first.
N.
Posted: Sun Oct 09, 2016 5:16 pm
by rumblenaut
Novem808 wrote:You may want to connect the Sub via USB to you computer/audio interface directly, and open the editor in stand alone first.
N.
This doesn't solve my problem, thanks for the reply though.
Posted: Tue Oct 11, 2016 12:48 am
by Novem808
It's the first place I would check. It's going to see if you have communication via USB from the Sub to your computer, and also see if the editor is working. If they are, you can go to your computer settings and reset your ableton connection, and start a new project to see if it's working.
N.
