Sequencer bug? (gate to run/stop for external control)
Posted: Fri Mar 04, 2016 5:28 am
by Tomavatars
Hey there.
I need to control the sequencer run with a daw or external keyboard.
Best way to do this seems to connect gate to run/stop.
It works well for the triggering of the sequence but there seem to be a bug :
- Notes are doubled, and the transpose is really weird.
- When hitting a note on keyboard (both external or M32 keyboard) it makes a new note between each already written notes in sequencer.
- It can sometimes transpose but with no logic.
Please give it a try to confirm the bug. I creates something interesting but I really need to transpose a sequence normally.
Re: Sequencer transpose bug?
Posted: Mon Mar 07, 2016 9:44 am
by Tomavatars
No clues? Does anybody tried this?
Posted: Tue Mar 08, 2016 9:40 am
by Wesley
You don't mention MIDI. Is MIDI connected in your patch?
If I use MIDI clock and connect the gate out to run/stop, each note tries to stop the sequence while the MIDI clock tries to restart it. Not good.
I would not connect the gate out to run/stop, as each note you play will start/stop the sequencer. If you are using MIDI clock, it will start and stop the sequencer for you.
You may also have a channel conflict, if MIDI is connected. You should check that too.
I run the Mother with my DAW and have no problems transposing from the DAW.
Posted: Tue Mar 08, 2016 1:41 pm
by Tomavatars
Hey there.
Thank you for the reply.
I'm using midi. No channel conflict seems to be involved. I will check this a bit further.
The behavior to start the sequencer with a note being played is exactly what I want to do.
I do not want the sequencer to be started on a midi start message but instead on a note on.
I can transpose from the daw, but what I REALLY want to do, is transpose and start sequencer at the same time!
Re: Sequencer bug? (gate to run/stop for external control)
Posted: Wed Mar 09, 2016 11:54 am
by andystyler
Out of interest, how are you connected, via midi input through din cable? Are you getting midi notes? I can't seem to get anything through mine, just a start stop signal
Posted: Thu Mar 10, 2016 12:53 pm
by Tomavatars
Yep connected with a midi din, in midi input. I get notes and start stop messages.
But I would like to be able to disable auto start of mother without having to filter the start message from the daw, AND trigger the sequencer from my daw.
Posted: Sat Mar 12, 2016 8:58 am
by bichuelo
Have you tried changing the tempo input behavior as shown on page 50 in the manual?
Posted: Tue Mar 22, 2016 9:42 am
by Tomavatars
I tried many patterns.
The fact is that the note played to trigger the sequence is played after the gate length of a note has end. Meaning that you can trigger a sequence well only if all the notes have gate length set to maximum. Even so, the sequence won't stop if you stop sending note.
So it doesn't work as I would love it to work.
Is there a way to just trigger and transpose patterns with midi without having to start the sequencer with clock?
It seems so obvious to me, that I find the behavior of the mother sequencer very weird.
Please I need to find a way to work like this!
