Power-One supply for modular
Posted: Tue Jul 07, 2015 1:07 pm
I'm considering using two Power-One units to power cloned Moog modules .
The 12v is no problem but for -6v I've been advised to use a Power One HC5v, modify it slightly , and swap the positive/negative out to deliver the -6v.
But would I have problems regarding grounding? ie using two separate transformers and regulator boards etc
I know Moog psu's use the normal dual supply ....what I am considering is using two totaly separate supplies for the two required voltages .
I don't know if this is possible .
