Distorted sound from headphone jack (sub37)
Posted: Thu Jun 18, 2015 4:04 am
by JazzMasta
Has anyone else had problems with distorted sound when using the headphone jack (with headphones)?
The line out sounds fine, but when using headphone I get a really overdriven sound (in a bad way).
The funny thing is, is seems to wear off as the instrument warms up, so after say 15 mins it's gone.
(There's nothing wrong with the headphones and I've checked feedback/drive knobs and have the osc-mixer pots att 12 o clock)
Re: Distorted sound from headphone jack
Posted: Thu Jun 18, 2015 8:28 am
by Subber37
If you are talking about the Sub 37 yes - I had this happen once , seemingly at random. Sounded like a dying op-amp! have only ever plugged stereo headphones in to it (and even then only twice). Kinda worrying and as it was random I fear it may eventually die for good after the warranty is out. I'm sure moog must have had people report this (and another thread on here mentioned it on the Sub Phatty)
Posted: Thu Jun 18, 2015 9:40 am
by Toom
I have the same issue as well. I asked about it. Andy said it might a loose connection for the headphone jack. But when I inspected the inside of the synth, the connection was fine. It comes back from time to time when I use my headphones.
Still no idea what could be causing it for sure.
Re: Distorted sound from headphone jack (sub37)
Posted: Mon Jul 27, 2015 5:24 am
by reedshere
I can only think of a headphone compatibility issue, and yeah - headphones do have compatibility issues. Check out some other equally good headphones, and the problem might not be there. I once noticed this with my Chrome headphones. Problem disappeared when I tested it out with my Grado RS2e.
Posted: Mon Jul 27, 2015 11:45 am
by Toom
I have the same issue as well. And it isn't a loose connection. I made sure of that.
When it does occur, it sounds like something is dying out. Looking forward to hearing what might be causing this.
