Page 1 of 2
Samll sequencer example Sub37
Posted: Mon Apr 27, 2015 12:05 pm
by mmarsh100
So I was fooling around with the new sequencer stuff in 1.1 (I am a beta tester) and this came out: https://soundcloud.com/mmarsh/sub37sequenced
What I find so compelling about this synth is that it is constantly leading me to music. I wasn't composing or in the creative flow or anything, in fact I was just about to go to bed (oh well!) I simply wanted to try something out with the new sequencer so I switched it on, did up a basic sawtooth patch, nothing special, and started tweaking a bit. I recorded a repeating four not sequence, again nothing special, and then over-dubbed a few notes. The I decided to add some Duo 'chords', again on overdub and this little thing started taking shape. Eventually, I recorded a single pass of the sequence, triggering the start point from the keyboard. It almost sounds over-dubbed to me...
Re: Samll sequencer example Sub37
Posted: Mon Apr 27, 2015 1:29 pm
by johnts
Very good, I have the inspiration now all I need is firmware level 1.1
Come on Moog.......
Posted: Tue Apr 28, 2015 9:56 am
by ChiLam
Brilliant! Very cool 8) - So this was created using several layers blended together then? Surely it's not possible to achieve this straight from a single take with the sequencer?
Posted: Tue Apr 28, 2015 12:26 pm
by _DemonDan_
ChiLam wrote:Surely it's not possible to achieve this straight from a single take with the sequencer?
ECHO...Echo...echo...
Posted: Tue Apr 28, 2015 12:39 pm
by mmarsh100
What Dan said ... What Dan said ... What Dan said ...
It was in fact a single pass which is why it was so exciting to me. It's really full isn't it? And harmonically interesting. The echo (MF Delay) and the chorus (also MF) help the illusion but the real trick is to put the sequencer in Record as it is playing back the sequence and adding two-note Duo mode chords here and there. A semi accident, I did this with intent but got an unexpectedly good result. Also, I'm using the Sub oscillator AND the Werkstatt as a third oscillator.
But
I didn't save the patch :roll:
It was late, I was sleepy. And I'm old.
Posted: Tue Apr 28, 2015 12:47 pm
by _DemonDan_
mmarsh100 wrote:But I didn't save the patch.
Just make it again:
http://a4.ec-images.myspacecdn.com/imag ... aa88/l.jpg :wink:
Posted: Tue Apr 28, 2015 1:03 pm
by mrberger
_DemonDan_ wrote:Just make it again:
Dang! sorry for the derail but are those T's available somewhere?
Back on topic. I would never have guessed that was one pass. Great job! Gotta love those happy accidents.
Posted: Tue Apr 28, 2015 1:06 pm
by dave500
Very nice :D
Posted: Tue Apr 28, 2015 1:10 pm
by _DemonDan_
mrberger wrote:http://a4.ec-images.myspacecdn.com/imag ... aa88/l.jpg
Sorry for the derail but are those T's available somewhere?
There was a time when Moog was giving them away at events.
I have two (one that I'm going to wear out, and another that I'll wear in the old age home;-)
Posted: Tue Apr 28, 2015 1:18 pm
by mmarsh100
Hey, you kids get off my lawn!
Posted: Tue Apr 28, 2015 1:21 pm
by mmarsh100
And, yeah, I'm gonna try the trick again and document it better. I do this a lot, find something cool and for whatever reason consciously don't save it. Weird.
Posted: Tue Apr 28, 2015 1:50 pm
by ChiLam
THANKS... Thanks... thanks...
Fortunate happenstances - I know exactly what you mean! :lol:
Wow - I can't get over this being one take. I have to try this out later - so run the sequencer, put it into record , switch on duo mode and add in some extra notes to make chords? It really did like more than a single pass.
Posted: Tue Apr 28, 2015 2:30 pm
by mmarsh100
Yep, that's about the size of it. I started with a very simple pattern and added chords where I thought they sounded good.
Also:
See what you started Dan? ... See what you started Dan? ... See what you started Dan?
Posted: Wed Apr 29, 2015 12:41 pm
by mmarsh100
Not to beat this one to death, but I did try to reproduce the patch last night with some success. Another thing that is important for the effect is to play with the Range and Back&Forth settings. Just FYI... Just FYI... Just FYI...
Re: Small sequencer example Sub37
Posted: Wed Apr 29, 2015 3:41 pm
by Tyler
Hey all you Sub 37 sequencers. This might be a well known fact but I just made a cool sequencing discovery with my Sub 37. I know that you can alter the sonic capabilities of notes in a sequences by simply playing with the sound parameters while a given sequence is playing back or cycling through a passage you've recorded. But I didn't know that by holding down notes, when building a sequence (take a basic 16 note sequence of 1/16th notes) from note to note, that you can actually record or capture the phrasing of the modulation of sounds ontop of the notes in your sequence as well (to create actual sound phrasing). Up until now I have only been making sequences (ex. rhythmic patterns of 16th notes - great). Now I seemed to have stumbled onto this possibility of creating not only rhythmic phrases but musical or sonic phrasing as well. Why with swing time added... this is going to draw out some major compositional innovations. Thanks again, Amos and all at Moog!
