EP-3 - adjust the volume with the expression pedal
Posted: Sat Feb 28, 2015 3:03 am
by mamomoog
I apologize for my English,
how do I adjust the volume of my voyager with the pedal?
I tried to add it in the input cv vol, but nothing
Thank you very much
Re: EP-3 - adjust the volume with the expression pedal
Posted: Sat Feb 28, 2015 2:32 pm
by Ledbetter
Are you using a tip-ring-sleeve cable? It will have two lines of black insulation material on the plug. Most instrument cables are tip-sleeve cables with only one line of insulation. Good luck
Posted: Sat Feb 28, 2015 6:29 pm
by mamomoog
Thanks, now I try
Posted: Sun Mar 01, 2015 12:01 pm
by thealien666
What model expression pedal are you using ?
Posted: Tue Mar 03, 2015 7:56 am
by mamomoog
I use a Moog EP-3 expression pedal
Posted: Tue Mar 03, 2015 10:14 pm
by bichuelo
mamomoog wrote:I use a Moog EP-3 expression pedal
With the original cable included?
