MiniFooger Delay Bypass Pop
Posted: Thu Jun 05, 2014 3:50 pm
When activating the delay I hear an audible pop, which is not altogether abnormal. However, it appears that this pop is introduced into the signal path before the effect, so the pop itself is run through the delay. As you can immagine, in ambient sound generating situations, this is a bit of an issue since the unit will self-oscilate the pop.
Anyone else have this issue? Or perhaps mine is uniquely malfuncitioning and I should get it replaced?
