Page 1 of 3
Ableton does not show the Minitaur Plug in :-(
Posted: Sat May 03, 2014 6:51 pm
by ANALOG MIND
Hi everybody,
im new in this forum and this is my first post.. sorry for my bad english!
i need some help please: i copy the minitaur editor 3.0 plugin in my vst folder but Ableton live cant find the
plugin :-( i also try to rescan my vst folder with live.. but still dont find it!
please help me..
its my first moog...
thx
Re: Ableton does not show the Minitaur Plug in :-(
Posted: Sun May 04, 2014 6:52 am
by Synth.builder
I'm getting the same here. The standalone version works fine via USB. But using Live 32-bit on Win 7 x64 the plug in is not showing up at all in the plugs list.
Tony
Posted: Mon May 05, 2014 8:18 am
by Bas
I have the same problem, using windows 7 64bit, Ableton Live 9 64bit.
So i put the minitaur.dll in my vst plugins and rescanned the lot. Nothing shows up.
Where is the minitaur pOLiCe. Please help us :mrgreen:
Bas
Posted: Mon May 05, 2014 8:40 am
by Bas
Double post 'removed'
Posted: Mon May 05, 2014 1:25 pm
by CleverConQueso
Ditto but in Reaper and 'VSTHost'.
Stand-alone works OK as long as you only have USB connected. If you have USB and MIDI DIN connected, it only works for a short time then the editor disconnects.
There's no audition feature in the editor so you can't hear your sound while you're using the stand-along editor.
Posted: Mon May 05, 2014 1:29 pm
by login
I am using both succesfully, plug in and Live must be both in 32 or 64 bits.
Also, they cant share the MIDI port (plug in and Live), minitaur plug use the USB ports and Live sequences the minitaur thrugh another midi interface.
Posted: Sun Jul 06, 2014 9:27 am
by angelj
Same problem here with Live v9 Win 7 32bit - Minitaur VST plugin does appear in Live.
Submitted a support request weeks ago, no reply from Moog yet.
Posted: Sun Jul 13, 2014 10:56 pm
by Systolic
See the "Minitaur Editor - Hardware Disconnected" thread.
Posted: Mon Jul 28, 2014 6:20 am
by amstrad
Same problem
Windows 8.1 64bit with ableton Live 9.1 64bit
I can use the standalone editor OK, send presets, etc.
When it comes to the plugin it just doesn´t show i my plugins folder. I´d need to integrate this with Ableton for a live performace.
Tried pasting the x86 dll in the x86 Vstplugins folder = nothing
Tried pasting the x64 dll in the x64 Vstplugins folder = nothing
Run ableton as admin, run ableton as standar user = nothing
Tried the same process with Live 8.3 = nothing
All test done with the standalone editor CLOSED = nothing
Turning off the minitaur driver in preferences = nothing
Turning on the minitaur driver in preferences = nothing
Went to a friend´s house with the minitaur and the editor. He also has Live 9.1 64bit running on LION OSX instead Win 8.1 = Plugin loaded OK
I´m i doing something wrong or is there some problem with the windows dll´s??
If someone made this work i would appreciate a solution (note this problem is not the "Minitaur Editor - Hardware Disconnected", i can interact well with the standalone, just the plugin doesn´t show in any of my DAW :( )
Posted: Tue Aug 05, 2014 4:56 pm
by Amos
Hi guys, there's a new build of the Minitaur editor which I think will solve this "not visible in the DAW" problem.
Please try it, and report whether or not it works!
Also a note that we're working on the "hardware disconnected" problem, although I don't expect that this Editor build will fix that separate issue.
download links:
http://www.moogconnect.net/downloads/mi ... INDOWS.zip [windows]
http://www.moogconnect.net/downloads/mi ... .1-OSX.zip [Mac]
Posted: Wed Aug 06, 2014 10:39 am
by Synth.builder
Hi Amos,
Live now sees the plug-in. However, it appears as an audio effect plug in and the channel the plug in is inserted won't send midi data.
Should it not be a midi FX plug?
Tony
Posted: Wed Aug 06, 2014 3:25 pm
by ashtarbrian
thanks amos!
Posted: Fri Aug 08, 2014 11:47 am
by ANALOG MIND
Amos wrote:Hi guys, there's a new build of the Minitaur editor which I think will solve this "not visible in the DAW" problem.
download links:
Hi Amo, the new minitaur editor plugin dont work again.. i cant see the plugin in ableton live.. im using windows 7 32 bit with ableton live 8!
and always if i plug the minitaur with a usb cable.. i always get noise on the audio output.. the sound is not clear... :-( i got the minitaur 3-4 month now..
but no fun only problems :-(((( so please help someone or i will sell them and never buy a moog again :-(
Posted: Fri Aug 08, 2014 3:24 pm
by Purusha
Doesn't seem to work with Cubase. :(
Posted: Sat Aug 09, 2014 5:15 am
by angelj
Sorry Amos,
Still not visible in Ableton Live :-(
(Win7 32bit/Live 9.14)
