LP pitch wheel problem
Posted: Sat Feb 01, 2014 6:50 am
LP owners please help me to understand if I have gotten a bad pitch wheel or maybe it's just the way it is.
Checking with external tuner, when I bend down and let it go, the pitch wheel returns in position were the overall pitch is slightly sharp (~ 5 cents). When I bend upwards it returns straight. This is really annoying... The wheel itself has some free movement on the middle. Very very slight, but still not fixing dead in the middle, most probably causing this issue.
In the middle notch position the pitch wheel has some slight movement without feeling any pressure of the spring. I can move it slightly up and down freely. Let's say, the notch groove is 5 cents wide. Maybe this is common on LP?
I try to understand if I should send it back and ask to fix this problem. Maybe that is something that I can fix easy myself.
In comparison my Microkorg's pitch wheel snaps straight in the middle...
