Buttons Not Very Responsive
Posted: Wed Jan 29, 2014 9:45 am
by SynthLord
Hi all,
I've recently purchased a Little Phatty Stage I and have noticed some of the rubber buttons require a strong push to activate. Having taken the panel off to have a look, I'm struggling to take it apart fully to access further. If you have any experience of this and can help with the following, I'd be very grateful:
1. What is the best way to take apart the synth to access the rubber buttons? I'm particularly having problems removing the small knobs from the volume, tuning and data input.
2. What is the best way to improve the responsiveness of the buttons once I have access?
3. Lastly, the screws to access the top panel do not look original to me. They are self tapping screws, which I guess are in the wrong place where somebody removed the side panels before?
SynthLord
Re: Buttons Not Very Responsive
Posted: Fri Jan 31, 2014 9:52 am
by jcsveth
I am curious about this, also. All of my buttons are hard to push. When pushing the ones around the display, I can see the LCD display warping a bit. I was actually curious if all units were like this. It makes editing and live manipulation while playing quite difficult.
Posted: Mon Feb 03, 2014 6:24 am
by SynthLord
So, I took the Phatty apart and cleaned the PCB and buttons very gently. It has improved some of the buttons, but not all. Does anybody have experience of using cleaning solution to do this? (I am worried about removing the black coating from the backside of the buttons.
Posted: Mon Feb 03, 2014 9:50 am
by EMwhite
Which buttons are you talking about, any in particular?
The Little Phatty, and many devices with 'rubberized' buttons use a system of exposed copper circuit board traces and something called impregnated carbon. In short, when you press the rubber-ish (silicon) button, the formed 'cup' of the button extends until the carbon (black) bit closes the contact 'switch' momentarily. The form of the cup then retracts to it's moulded state.
These are used on the Phatty panel and Taurus III panels for sure but also on the inside of virtually all modern synth keyboards and all sorts of other devices. If you dissect any keybed manufactured after the early 1980s, you'll find two of these under every key in the form of strips of 3, 4, 5, or 6 at a time. In the keyboard use case, the first set initiates contact or key press on, then 2nd makes contact just a fraction of a second afterwards and the cpu of the synth determines velocity by measuring the time between each press.
The nemesis of each scheme is either the silicon/rubber body tearing thereby making contact or retraction unreliable, or dirt/grime getting into the fixture, making contact unreliable by requiring a harder press. A third problem exists when the copper board traces or (more likely) the impregnated carbon wears. Here is an outfit that manufactures these if you want to read just a bit about it: http://www.topboundusa.com/silicone-rubber-keypad.html
Since the Little Phatty uses two half sheets and is otherwise, seemingly sealed, it is unlikely that dust or spilled beverage (in the case of a keyboard) will spoil the works. But normal wear and oxidation can cause the copper to tarnish or the carbon to wear, especially if the board contact points are not smooth and if repeated mechanical motion of button press against the contact point is not on a direct z-axis plane (e.g. perpendicular into the board). It should last for ages, especially since this is not a new 'technology' but maybe if you bought your Phatty 2nd hand, somebody kept it on the deck of their oceanfront vacation home. Don't know.
It would be good to inspect and clean but definitely be careful NOT scrape the black off of the buttons but do clean them if you can, definitely DO (very carefully) clean the board with q-tips and alcohol solution. I've had great luck with this (see this SynthFreq video http://www.youtube.com/watch?v=-czedYcY1mA ) on my Matrix 6 keyboard, it literally brought several keys back to life and improved the reliability of misfiring keys. DO check with Moog on their recommendations. You can buy a new panel if there is noticeable wear either from Moog or here: http://www.instrumentalparts.com/kbd-04-000-0001.html and http://www.instrumentalparts.com/kbd-04-000-0002.html.
Fun fact: did you know that the Taurus III pedals uses the Little Phatty kbd-04-000-002 part? (yes, the OSC and Env gen buttons are flipped upside down for use on the Taurus III)!!!
With regard to the question about the 'self-tapping' screws. This is normal though it's possible that a prior owner took yours apart and didn't put it back together properly. The side panels should be held together with 3 self tapping screws which are used to connect the side to the aluminum extrusion (back panel); and the remainder per side are machine screws.
Whatever you do, be careful, and CONSULT MOOG TECH SUPPORT before doing anything and/or proceed at your own risk. I have a long history of taking apart, messing with, and re-assembling gear and a 99% success rate. The 1% was the time I took apart a watch and couldn't get it back together... you only do that once! :D
FWIW: I asked which buttons are not quite working well because if it's the envelope generator buttons and you are accustomed to having these in EGR Auto mode (holding a button while turning the value pot), this is normal. Turn EGR scanning to ON if this bugs you. Not sure if this applies to the Stage edition but it is worth mentioning.
Posted: Tue Feb 04, 2014 9:47 am
by jcsveth
EMwhite, thanks for that. Interesting. All of my buttons are hard to press with the hardest being those around the display - this actually makes it tedious to program. I find I program on my Sllim Phatty (whose buttons are awesome) and transfer to the LP. I had sent my LP in for the analog CV mod and assumed if the buttons were out of spec, Moog would have mentioned it. That is why I was wondering if all LPs were this way.
Posted: Sun Apr 27, 2014 2:48 pm
by SynthLord
Thank you for the detailed information. In the end i've had excellent results using this cheap fix:
http://www.ebay.co.uk/itm/KEYPAD-FIX-Pe ... 19eb41a1f7
2 coats over 3 hours and it works amazingly well!
