RML Circuit Bent Mutron III w/ 6 Step Knight Rider Sequencer
Posted: Fri Nov 08, 2013 7:47 am
by robml
hey guys- was wondering what you thought of this for entry into the moogfest circuit bending comp.
are you allowed to take parts of a schematic from a circuit and recreate it or do you need to have a physical existing unit to mod?
there are so many requirements to entry, i dont want to waste my time complying with them all to be told im not using an existing device ;)
I have not created a video like other people documenting the process, just the end result ;)
i took the filter out of the mutron III and ditched the volume detection and replaced it with a 6 step sequenced circuit (think knight rider dash display) designed with a 555 timer.
i also modded the resonance on the mutron III filter, pushing it so it sounds sweet (read: bleeps and tweets)
heres a demo of it hooked up to the minitaur.
http://www.youtube.com/watch?v=g6lt9qznHx0
the right box is the modded mutton III filter, the left box is the 6 step sequencer which affects the frequency of the filter sweep at 6 different points.
the knobs on the filter are LP/HP/BP - Filter Center Frequency - Resonance
the knobs on the sequencer are the 6 filter strength knobs and a speed knob
the back and forth swing of the sequencer gives it a natural feel unlike step sequencers that simply restart.
let me know what you think, worth entering into the moogfest circuit bending comp ? ;)
would be cool for an Octave One kind of setup for live performance.
cheers
Re: RML Circuit Bent Mutron III w/ 6 Step Knight Rider Seque
Posted: Fri Nov 08, 2013 1:23 pm
by VCS3
Sounds cool, good job! :)
Posted: Sun Nov 10, 2013 10:31 am
by EricK
I would comply with the rules.
Posted: Sun Nov 10, 2013 3:23 pm
by robml
EricK wrote:I would comply with the rules.
i would like to eric ;) just need to make sure i am ;)
Posted: Tue Nov 12, 2013 2:16 am
by modoc_333
you said you didn't make a video, but make sure you document the build step by step or it won't comply. I think you are already outside of the rules because it clearly states you must start with an EXISTING device. NOT building it from a schematic.
Posted: Tue Nov 12, 2013 4:30 am
by robml
i will make a proper video, if i get told it's ok for entry.
i am starting with an existing device, in the sense that im not starting with a new design.
no one is going to actually modify their existing Mutron III. have you seen the asking prices on ebay ;) besides if i create the boards from scratch everyone else can make one too ;)
i've sent an email to the guys at moogfest. we'll see what they say.
cheers ;)
Posted: Tue Nov 12, 2013 11:30 am
by modoc_333
you're right that no on would mod a mutron iii for this... but that's the point. YOU chose the Mutron. THEY want you to do it with something cheap. That's why they put the $70 limit on it. and it doesn't say existing design. it says existing device. Let us know what they say, but I think the fact that you have a question, and are trying to make your design fit are evidence that you know it doesn't really. If you have to explain, then it doesn't.
Posted: Tue Nov 12, 2013 2:28 pm
by robml
well moogfest they got back to me
they said i needed to "utilize a pre existing physical product" (paraphrase)
which kind of sucks.
for me "circuit bending" does not necessarily mean "physical device bending". imo i bent the circuit of an existing device and created a new instrument out of it.
disappointing. oh well.
good luck with your speak and spell entries. ;)
cheers
Posted: Tue Nov 12, 2013 2:43 pm
by robml
modoc_333 wrote:you're right that no on would mod a mutron iii for this... but that's the point. YOU chose the Mutron. THEY want you to do it with something cheap. That's why they put the $70 limit on it.
yep. i could have done a kit for $25. i did mine for free using scraps on my work bench.
modoc_333 wrote:and it doesn't say existing design. it says existing device.
yep - the mutron III is an existing device. yep - i bent it's circuit.
if i do it in the box it complies. if i do it on vero it doesnt comply. seems like a thin line to walk and not in the spirit of bob moog.
modoc_333 wrote:If you have to explain, then it doesn't.
thanks for setting me straight guy.
