SUB PHATTY Aftertouch question
Posted: Fri Oct 25, 2013 8:36 am
Hi.
I recently have got the new SUB PHATTY and sucessfully updated to 2.0.1 firmware, which was provided with the software editor by email after synth's registration.
My question is about the aftertouch support in SUB.
I know that SUB PHATTY's own keyboard doesn't support aftertouch, but I believe that the synth engine itself may support aftertouch, since it is all-midified.
So, what I want is at least:
1) To assign the aftertouch as kind of independent modulation control for some parameters, at least the same as the main mod section:
LFO -> PITCH
LFO -> FILTER
LFO -> WAVE
2) To set the modulation amount of the aftertouch for each of these destinations.
3) To be able to set (1) and (2) from Sub Phatty's front panel in "shift mode" and via the software editor
4) To save the aftertouch setting as patch-level parameter.
For example, for my keyboard technique it would be great to use afterouch for pitch vibrato and to use mod wheel for filter eg amount (or vibrato), separately.
That's what I'm actually do with my Nord Stage 2, where afterouch is multi-assignable to some parameters, for each patch, and allows to do funky tricky stuff.
And I want to connect Nord Stage as external keyboard to Sub Phatty and do some aftertouch tricks on the Moog little monster.
Maybe some aftertouch is already implemented in Sub Phatty, but I can't find this in the manual.
Thanks.
LFO -> PITCH
LFO -> FILTER
LFO -> WAVE
Thanks.
