Noob question: Roland EV-5 with minifoogers?
Posted: Mon Oct 21, 2013 5:25 pm
by l4rs3rik
I have a Roland EV-5 expression pedal, will it work with the minifoogers?
Re: Noob question: Roland EV-5 with minifoogers?
Posted: Mon Oct 21, 2013 10:09 pm
by kn_s
can't give you too much advice on this because i too am new on the moog action ( also anxiously awaiting for my minifooger delay), but i can say that the roland ev-5 works on the regular moogerfoogers but the range of the pedal is not quite as wide as my moog ep2. i'm sure it'll work with the minifoogers as well and probably with the same response as their bigger brothers????
Posted: Mon Oct 21, 2013 10:46 pm
by Ledbetter
Buy a Moog pedal, it's even cheaper!
Posted: Tue Oct 22, 2013 1:49 am
by l4rs3rik
kn_s wrote:can't give you too much advice on this because i too am new on the moog action ( also anxiously awaiting for my minifooger delay), but i can say that the roland ev-5 works on the regular moogerfoogers but the range of the pedal is not quite as wide as my moog ep2. i'm sure it'll work with the minifoogers as well and probably with the same response as their bigger brothers????
Ok, thanks.
Posted: Fri Nov 22, 2013 6:59 am
by l4rs3rik
A little update, I got a drive a few days ago. So far very happy with it, works great on both guitar an bass.
The EV-5 does work but the range is no doubt limited compared to the youtube videos I've seen where people use a moog pedal to control the filter cutoff.
Posted: Fri Nov 22, 2013 1:11 pm
by Ledbetter
EV-5 voltage is plus or minus 3, Moog EP-2 voltage is plus or minus 5, from which I conclude that EV-5 range is 60% of EP-2 range.
Posted: Fri Nov 22, 2013 1:49 pm
by Portamental
Sure about that? An expression pedal powered by a +5 volts supply (ring) can only provide positive voltage.
Posted: Fri Nov 22, 2013 9:27 pm
by Ledbetter
Pretty sure that's the range, read it here I believe. I know the 3 and 5 volts figure is correct, checked before posting.
