flange with a 104, do you think this would work?
Posted: Tue Nov 15, 2005 5:41 am
i started writing this trying to solve the problem of freq loss in the long setting on the 104 but came up with something quite different.
feels weird quoting myself but hey you might have missed it otherwise.could you run the hi hats through a pitch shifter going an octave down before it hits the Z then through another one going an octave up after it comes out to of the delay get the correct pitch/frequencies using the delay.
Hang on i just realised that would make the delay 2x faster (if it were 1 octave down then 1 octave up) so you could just flip it to short mode anyway and save yourself 2 pitch shifters.
still i'm sure you could do some cool stuff with this, like getting the Z/SD/original to flange!
first go 2 octaves down
then use the delay
then go 2 octaves up
correct pitch and the delay is magically four times faster, so just modulate it a bit and there's your flanger!
hmm all i need now is 2 pitch shifters, anyone know of any good but cheap pitch shifters?
