Sub Phatty with digital effects from a DAW?
Posted: Mon Sep 23, 2013 2:36 pm
by Corianjackson
Can't afford any decent analog pedals at the moment. Does this defeat the whole purpose of having an analog path?
Re: Sub Phatty with digital effects from a DAW?
Posted: Tue Sep 24, 2013 7:54 am
by Bald Eagle
I don't want to get into the whole analog vs digital debate but my take on it is that if it sounds good then do it. If you're an analog purist then I suppose it defeats the purpose. I sometimes use a Korg M3 for effects and also Sonar. And in the end its all recorded digitally.
Posted: Tue Sep 24, 2013 11:07 am
by CleverConQueso
Some effects like delay can be run in parallel nicely. Then you can use your mixer like a wet/dry knob. I do this mostly to keep my band-mates off my back on the analog/digital debate.
Posted: Tue Sep 24, 2013 12:08 pm
by mmarsh100
What BaldEagle said :) (if it sounds good, do it). Also, there are some effects you cannot achieve (easily) in a pure analog way. Granular-based effects come to mind.
