Page 1 of 2
YES!
Posted: Fri Sep 13, 2013 4:26 pm
by CleverConQueso
Sub P. editor is in the hizzy.
Re: YES!
Posted: Fri Sep 13, 2013 4:52 pm
by fxavier
yes!!! :P
Re: YES!
Posted: Fri Sep 13, 2013 5:15 pm
by djintel
Just got it up and running, this will be very cool. Can't wait for some preset packs to come out, but seems the Beta Team already put some in there so well worth the wait. Now this and my Virus TI are unstoppable.
Re: YES!
Posted: Fri Sep 13, 2013 5:39 pm
by memhpis1212
How do you have yours setup? Mine's telling me that the hardware is disconnected, and it also keeps crashing and force quiting. =/
Re: YES!
Posted: Fri Sep 13, 2013 8:50 pm
by CleverConQueso
Windows 7/32. USB. Using the stand-alone. No trouble to report although I'm still sorting out how it works. The 'prefs' button is right-side, about halfway down and has the MIDI communication settings.
Re: YES!
Posted: Fri Sep 13, 2013 9:03 pm
by gencomprodukts
Hi there,
Big trouble with the editor on my unit.
I can load or save patches with the Standalone editor (W7/64 bits) but no communications between the knobs on the editor and my Sub Phatty, it doesn't work.
I checked the prefs and everything is ok but if i turn any knob on the editor, i have absolutely nothing on the SP. Any help? Thanks in advance.
Re: YES!
Posted: Fri Sep 13, 2013 10:29 pm
by djintel
anyone try out the 64bit vst yet? from what it says it seems you have to disable midi in daw and load vst onto an instrument or external audio track.
Re: YES!
Posted: Sat Sep 14, 2013 12:47 am
by mckayallday
memhpis1212 wrote:How do you have yours setup? Mine's telling me that the hardware is disconnected, and it also keeps crashing and force quiting. =/
I'm excited to use this, too, but it keeps quitting before I can. Anyone else on MAC using OS 10.6.8 successful in using the editor? I am able to choose the sub phatty in the MIDI in and out in the editor prefs. After a second, it crashes and quits. Maybe there's a fix someone has thought of already?
Re: YES!
Posted: Sat Sep 14, 2013 2:04 pm
by CleverConQueso
gencomprodukts wrote:...everything is ok but if i turn any knob on the editor, i have absolutely nothing on the SP.
I'm the same but honestly, I don't know how it's supposed to work. From my experience with DSI stuff, I'm used to the knobs not turning in both places except when the wind's right. What I've been doing is downloading the patch from the Sub Phatty, tweaking, saving, then sending it back up. I'm assuming in a perfect world the two devices will be more interactive but in the meantime, getting the whole scene at a glance is a step up for me. I haven't tried it as a VST yet which I imagine would have to be more interactive but not my use case.
Re: YES!
Posted: Sat Sep 14, 2013 2:33 pm
by gencomprodukts
I finaly found the solution, now it works!
Choose Midi Channel 1.
My unit had Channel 2 and it seems that the Standalone editor ONLY works with Channel 1.
Re: YES!
Posted: Sat Sep 14, 2013 8:28 pm
by gorgolath
i am using windows 7 64 bits and when i use the editor in stand alone it is working perfectly but i got a problems when i try to use it in vst version ,the preferences are not kept and of course the editor vst is useless .i am trying to figure out what is wrong.any help is welcome.
Re: YES!
Posted: Sun Sep 15, 2013 3:18 am
by Rob S
gencomprodukts wrote:Hi there,
I had the same problem until I started the editor when the Sub Phatty was already turned on and connected. You may try that
Re: YES!
Posted: Sun Sep 15, 2013 9:43 am
by mixpan
Many problems here also. I keep getting a "hardware disconnected" message at the left side of the prefs screen (Firmware: ...) randomly.
The system is running on Windows 7/64, so I have to disconnect my Subphatty from the DAW's midi in and outs and only use the editor's Midi i/o instead. But then I can neither give record any note- midi messages from the DAW nor record any playable automation! Amos, please help!!
Re: YES!
Posted: Sun Sep 15, 2013 10:57 am
by gencomprodukts
Thanks Rob but as i said i finaly found the solution. My SB had Midi Channel 2 and the Standalone editor ONLY works with Channel 1. Pretty weird... There is no communications between the knobs & the Standalone editor if the unit is not configured to receive on Channel 1.
Would be great to correct this in the future.
Re: YES!
Posted: Mon Sep 16, 2013 11:50 am
by Amos
gencomprodukts wrote:There is no communications between the knobs & the Standalone editor if the unit is not configured to receive on Channel 1.
Maybe you didn't set the Editor to use Channel 2 in the Prefs, at first? I am using the Standalone editor with my Sub Phatty on Channel 2, no problem. Just had to set MIDI In/Out to 2 in the editor preferences page and it's working fine, for me. Win7/x64
