[ RME Issue ] Pedal modulation section - Dead.
Posted: Sun Jul 07, 2013 3:16 pm
Hi there,
after a retuning session of my Voyager RME, i made a full check before closing the chassis and everything worked great.
I left it off for some hours, then switched on again to play and the issue happened.
To avoid long descriptions, the issue is shown on this short video.
http://www.youtube.com/watch?v=_mGQTOfvcPg
Mayor checks already done:
I've checked all the flat cables removing and inserting them back into their sockets, I've made this on both the synth card and the front panel cards.
Panel factory reset, just as desperation maneuver.
Recap after check:
- LFO is woking, beacuse it modulates the mod wheel-activated section
- Mod wheel section is working properly.
- Pedal section's pots and rotary switches are all working fine as the digital encoder recognise them.
- NO modulation from this section.
There is no warranty anymore on this Voyager 'cause i bought it used.
Any help is very very very very much appreciated.
Recap after check:
