Keyboard octave issue
Posted: Thu Jul 04, 2013 12:09 pm
by Guitarmin
I don't know if this has been reported before, but the keyboard octave buttons on my Sub (as we now officially call it ;-) ) just died. I was using it with Maschine, the unit being connected to my Mac via USB. The LFO modulated the waveform with the mod wheel being in maximum position. First I had turned the sub oscillator all the way up, then I decided to turn it down and lower the keyboard octave instead (from 0 to -1). When I did that, it suddenly switched to the lowest octave and didn't react to the buttons anymore. When I pressed the "octave up" button, the -1 light just flashed briefly and that's it. Everything else was still behaving normally.
I powered the unit down and up again and the issue instantly occurred a second time when I tried to alter the keyboard octave. I turned it off and on again but also moved the mod wheel this time which apparently solved the problem - but that might well be coincidental.
I'm using firmware 1.2.8 if that's of any help.
Re: Keyboard octave issue
Posted: Thu Jul 04, 2013 1:26 pm
by Guitarmin
It just happened again, this time with Ableton Live.
Posted: Thu Jul 04, 2013 2:01 pm
by IgorCristo
If you're using the Editor or MIDI connection, this might be a bug. Did you try it without connecting the Sub with a PC/Mac??
This didn't happen to me, but occurred within the Editor, wich by the time wasn't sending MIDI to my Sub. When I switch an octave down, the Editor gave me a -2 in the screen.
Amos should be able to assist you in this...... I should also contact him about this thing I've experienced with the Editor.
Cheers!
Posted: Thu Jul 04, 2013 2:49 pm
by Amos
Yes sorry about that -- v1.2.8 was really just a quick test to see if the filter cutoff bug was fixed, which it seems to be... but that's not a stable release. I'm taking the rest of today off but I'll be working on firmware again tomorrow. These things should be simple to fix.
