new MOOGERFOOGER pitch-shifter!!!!
hey guys
I read about new moogerfoogers all around this forum the last weeks and I mentioned that nobody thought of a real moogerfooger pitch-shifter. Like POG (ehx) for example or the WHAMMY(ies)... huh? what do you think? imagine an analog pitch-shifter where you would be able via the cv inputs to control higher octaves, fifths e.t.c. with an exp. pedal. An analog moogerfooger whammy...
Mike get to work!!!
regards
Mike get to work!!!
regards
www.myspace.com/gravitysaysi
gravitysays_i
gravitysays_i
You can get lower pitches easily enough with a frequency divider, it's higher pitches that are tricky. It only works with a monophonic signal, too. It's kind of possible with a ring modulator, but far from the results you'd get with a digital device.
The ideal situaion would be a digital device with CV inputs for control.
Maybe we can't have a pitch shifter...but a Bode frequency shifter would make one sweet looking moogerfooger ![Shocked :shock:](./images/smilies/icon_eek.gif)
guitars, amps, normal pedals;
MF101, MF102, MF103, MuRF, CP251;
Sequential Circuits Prophet 600;
Roland JX-8P, Roland Alpha Juno 2;
Ensoniq ESQ-M, Yamaha TX802, Kawai K5000r;
Alesis Quadrasynth Plus Piano
An analog octave pedal is easy to do because you are just multiplying the signal by itself. Similar to ring modulation only instead of multiplying the input signal by a carrier signal, you simply multiply it by itself. This results in two frequencies: one at twice the frequency of the input (doubling frequency means it sounds an octave higher) and one at 0 Hz (which is inaudible). You can do it with the Moogerfooger Ring Mod by using a Y-cable to insert your audio input into the carrier in. This is not the same as what a pitch shifter can do.
I was way ahead of you on the pitch shift trick with the ring mod - and it doesn't work very well. It only works for waveforms with few harmonics and you only get octave pitch shift, no semitone or micropitch shift.
I asked Moog Music about the ring mod trick and they said it is a limitation of the multiplier IC used in the ring mod. That makes sense if you do the math with higher harmonics - the modulated harmonics increase in frequency EXPONENTIALLY and they exceed the bandwidth of the IC in a hurry.
An octave pedal is a divider, not a multiplier. It generates a pitch that is an octave lower than the original. Divider circuits are much simpler than multipliers. The simplest divider can be built from a TTL J-K flip-flop IC.
That's how they make suboscillators for VCOs - it's an octave divider circuit.
The only con with dividers is that the output waveform is a square wave. You can filter it but in most cases it won't resemble the harmonic structure of the original waveform.
hey... how come electroharmonix is doing it??? ( www.ehx.com ..POG pedal..) If electroharmonix is doing it then moog will definetely do it better. right?
gravitysays_i
gravitysays_i
