New Sub Phatty - No sound
Posted: Sun Jun 16, 2013 5:59 pm
by horm
I just bought a new Sub Phatty at a retailer two hours ago. I brought it home, plugged the power cable in, ran a 1/4" TS cable from the Audio Out jack to my amplifier, and turned the synth on. The panel preset and control lights came on, but no sound is produced when I press keys on the keyboard. I made sure the Master and Headphone dials and the Oscillator Mixer dials were turned up, and currently every dial on the control panel is facing 12 o'clock. I tried using headphones as well. Still no sound is produced when I play the keyboard. An expected popping noise can be heard in the headphones when i turn the device off and on.
Any ideas?
Re: New Sub Phatty - No sound
Posted: Mon Jun 17, 2013 7:30 am
by ul303
Check you have local on activated.
Posted: Mon Jun 17, 2013 9:12 am
by Waza
have you tried with headphones?
Posted: Mon Jun 17, 2013 9:19 am
by breun
Waza wrote:have you tried with headphones?
horm said: "I tried using headphones as well." :)
Posted: Mon Jun 17, 2013 11:02 am
by JohnWynberg
Ok, this may sound too obvious, but I made that mistake once: Are you sure you connected your amplifier to Audio OUT and not to Audio IN?
Posted: Mon Jun 17, 2013 11:21 am
by stiiiiiiive
I did taht too, but he's having no sound through the headphones output neither.
Local setting it is, me say.
Posted: Mon Jun 17, 2013 4:41 pm
by horm
Already went back to the shop and exchanged it for a new unit. Looking back, the Local Control setting was probably the issue. I must have missed that when i went through the manual. I wish the admin had approved my post sooner so I could have solved the problem.
Posted: Mon Jun 17, 2013 5:58 pm
by Amos
http://www.moogconnect.net/downloads/su ... v1_1_4.pdf
try the "initialize globals" command...
Posted: Tue Jun 18, 2013 3:41 am
by ul303
Amos,
re this sheet it seems that the USE PRESET KB OCTAVE does not work...At least it does not go back to normal mode when you press C or C# twice.
Posted: Wed Jun 19, 2013 3:31 pm
by Amos
ul303 wrote:Amos,
fixed -- thanks! :)
