Sub Phatty additional hidden parameters issue
Posted: Wed May 15, 2013 12:31 pm
by Bjornw
In activate panel-mode. When turning power off for a long time it seems some hidden parameters go back to original values. I.E. filter envelope trigger mode. I want it to retrigger when playing legato. If I have to do these settings every time I start and use panel mode I don“t get that fast hands on, play and tweak but have to go through a bunch of hidden settings and then start playing. Anyone else had this problem?
Re: Sub Phatty additional hidden parameters issue
Posted: Sat May 18, 2013 4:07 am
by Howard Scarr
I noticed that active-panel mode often adopts hidden parameters from the previously selected preset (at least it seemed that way to me).
Also BTW, the saved mod wheel position isn't always applied when I load a preset (despite having set that behaviour in the global settings).
Posted: Sat May 18, 2013 8:08 am
by till
Howard Scarr wrote:...
Yes, I can recreate this by selecting three different patches in a different sequence. one patch will be with modwheel amount stored and the very same patch will be without if the other preset is selected before this one.
Posted: Sat May 18, 2013 11:07 am
by marty
This happens to me too. Taking my Subby out on the road tomorrow for a first short little tour but thinking using presets for live performance is gonna be hairy until this is resolved.
Posted: Tue May 21, 2013 4:37 pm
by Amos
Hello all... some of these problems are definitely resolved in the current (beta) firmware, v1.2.1
(available here.)
If you are using the latest firmware and are still experiencing any of the above problems, please let me know as soon as possible. Thank you!
(firmware update instructions, if needed: http://forum.moogmusic.com/viewtopic.ph ... 15#p115528)
Posted: Wed May 22, 2013 7:18 am
by Howard Scarr
This one (at least) isn't fixed in the 1.2.1:
Me: "the saved mod wheel position isn't always applied when I load a preset (despite having set that behaviour in the global settings)."
Posted: Wed May 22, 2013 12:57 pm
by misterpete
confirmed here... bummer ~ similar to the Taurus MOD Wheel issues ??? :(
I'm wondering if some other "Global" parameters aren't saved... ~ particularly VOLUME - which seems especially counterintuitive, defaulting to the preset volume
Posted: Wed May 22, 2013 5:59 pm
by Amos
All right, let's try this one. I found a place where I might not have been updating the mod wheel amount correctly under some circumstances... thanks for checking it out:
http://www.moogconnect.net/downloads/su ... _1_2_2.syx
Posted: Thu May 23, 2013 5:12 pm
by till
The new firmware 1.2.2 helped!
The mod wheel value is now used according to the global modes.
