Page 1 of 8
Taurus 3 firmware update - v2.0.3
Posted: Thu Mar 28, 2013 4:20 pm
by Amos
Hi all! I fixed some Taurus 3 bugs this week, and added a couple of features.
This should probably be called version 2.1.0, but I'm tagging it 2.0.3 since it's not been officially tested yet and this isn't an official release. It seems to work though; maybe you'd like to check it out as well.
Fixed: MIDI OUT filtering works now (can choose not to send Volume CC7 from volume wheel, or no CCs at all from either of the footwheels, only notes). Also, MIDI CC output should be better.
New: Can save footwheel volume per preset, can save pedal transpose per preset.
http://www.moogconnect.net/downloads/ta ... 8Mar13.syx
cheers,
Re: Taurus 3 firmware update - v2.0.3
Posted: Thu Mar 28, 2013 5:38 pm
by Mr Arkadin
Nothing seems to happen at my end. I get a brief message saying "Updating..." (it is too brief to see the rest of the message) and then nothing seems to happen. Is it supposed to do the full count up and reset like previous updates?
Posted: Thu Mar 28, 2013 6:50 pm
by Amos
yes, it should follow the same routine as all the previous updates.
I know it works for me and at least one other fellow... make sure FW UPDATE is enabled (Master menu, System utilities page), this defaults to Off every time so you need to set it manually before sending the update. If you've done that already, try changing something about your MIDI-sending situation (switch to USB, switch from USB to a 3rd-party interface, update the drivers for said interface...)
Posted: Thu Mar 28, 2013 8:48 pm
by Mr Arkadin
Got it working. The key is to NOT use the USB, but use regular MIDI and it works. Haven't tested anything yet though.
Posted: Fri Mar 29, 2013 10:37 am
by Mr Arkadin
Amos wrote:New: Can save footwheel volume per preset, can save pedal transpose per preset.
Only just read this - this will be great for quick changes even within one song - a bit like hitting the Octave switch but with any transpose avaialble. Nice one.
I think I've been one of the most vocally downbeat about T3 continuing development so a big thumbs up and a pint if you get to London. Here's looking to v2.5 and ultimately v3.0.
Posted: Fri Mar 29, 2013 10:19 pm
by EMwhite
Amos wrote:Hi all! I fixed some Taurus 3 bugs this week, and added a couple of features.
cheers,
Are you wearing a Santa hat and going on UHF TV touting that it's Christmas in April? : )
I was perfectly happy with the code in my Taurus (which is old by any measure) because when I stomp on dem pedals, the house shakes, but kudos and thank you for not leaving the faithful in the dust.
Posted: Sun Mar 31, 2013 5:07 am
by sunny pedaal
gone try him , thanks very much again
Posted: Mon Apr 01, 2013 1:26 am
by PaulieBe
GREAT UPDATE.
Thank you Amos. It all works like a charm.
I really needed all of those new features. You guys are tops.
Best, PB
Posted: Tue Apr 02, 2013 10:37 am
by xsubs
Thank you Amos... very pleased you're not forgetting us T3 users. Seems that every post lately is for the Minitaur... cool synth, but a toy next to the T3
Posted: Tue Apr 02, 2013 11:45 pm
by Voltor07
I'll be loading this ASAP! Thanks a lot, Amos!
Posted: Wed Apr 03, 2013 11:15 am
by bichuelo
I have tried installing this update using Sysex Librarian and MIDIOX with success.
However, after the update, most parameters (if not all), have a very limited range compared to version 2.0.2. Can anyone reproduce this behaviour?
Posted: Wed Apr 03, 2013 3:17 pm
by metron
You might need to recalibrate the control wheel? After the first firmware update I did I noticed I couldn't easily zero whatever parameter I was controlling. Recalibrating worked perfectly.
Posted: Wed Apr 03, 2013 8:40 pm
by bichuelo
Well I did the calibration procedure, without success. The number on the display reads out correctly, but the parameters are really at 1/4th of their usual value.
I tried using external controllers (7 or 14-bit) too, and even though the display on the T3 doesn't update in realtime, the same thing happens.
Everything works as expected when I roll back to 2.0.2
Posted: Wed Apr 03, 2013 10:49 pm
by Amos
hmmm, interesting! evidently, this is not the same for everyone.
I'll compare the two versions carefully, to see what could be the difference.
Thanks for your tests!
Posted: Thu Apr 04, 2013 2:40 pm
by misterpete
Hello and thank you Amos!
FYI The FW 2.0.3 updated successfully (via USB) without a hitch — following instructions from the last T3 update using the supplied SYsEx app
Unfortunately, as far as I can tell either this FW update still hasn't addressed the ARP/TRANSPOSE problem I bugged you about ~ or perhaps I have just not set something right in the T3 menus?
Problem remains — Sending notes out from Arpeggiator works properly only until I hit the transpose button after which the T3 plays the transposed notes but the MIDI notes going out do not change from the original pattern... is there something else I need to do within T3 menus or has this just not been addressed yet?
many thanks, Pete
