Maybe we have units that were on the same batch, because that one right there also happened to me, amongst other things I don't remember.Solum wrote:I also have the problem of freezing, especially when you do not use the synth for some half an hour or more and then want to go back to the Minitaur.
The more severe problem I have was mentioned before by others. Somehow saving presets does not work well. You need to turn every knob on the Minitaur so the editor finds the current position. Opening a preset from the editor and going on from there is tricky when saving the sound. Knobs that were not touched are then often saved incorrect as if the editor could not find the current position of the knob.
I like the sound of this little bugger alot but problems with incorrectly saved sounds are bad and reduce the fun and proffesional aspect much.
For example I wanted to send in a track this week for mastering. I needed to record the bassline again and opened the saved preset within the editor and was shocked on how wrong this sound was saved. I am now still working on that bassline in order to find the perfect settings I had some days before...
I just updated to 2.0.4 let's check this out boys and girls.
