OK, here is another update (joyeux anniversaire, clement)
http://www.moogconnect.net/downloads/mi ... 2_0_11.syx
this is v2.0.11 (I will advance to v2.1 when all obvious bugs are fixed).
In this version:
(1) RELEASE MODE 2 is changed. No longer must you hold the RELEASE ON/OFF switch while turning the Release knob. Whose idea was that, anyway? (mine; I apologise) ... now it is simple. If RELEASE on/off is lit, the DECAY/RELEASE knob is editing the Release time. if RELEASE On/Off is dark, then DECAY/RELEASE knob is editing Decay time. Release Mode 1 behavior is unchanged; still v1.0 Minitaur behavior (which is: Release on/off sets release time to zero when off; release and decay times are linked when release is on). Press and hold Release On/Off for >1sec to toggle between modes 1 and 2.
(2) VCA "off threshold" from previous version was removed. This value was too high, and was causing the VCA not to close completely on some units (leaving a "ghost" of a note still playing).*
* -- you can calibrate this "off threshold" precisely for your unit, if you like. Don't worry if you don't want to do this... the default setting is zero, which is the same as v2.0 and older firmware (so, if you don't do any calibration, everything should be the same as you were used to). However, a calibrated VCA off threshold should provide smoother envelope release.
To do this calibration, connect the minitaur to a good sound system, play a note, and after the note has decayed to silence, turn up the sound nice and loud.
Next, send this sysex file:
http://www.moogconnect.net/downloads/mi ... o_end).syx
You will see the GLIDE switch light blinking on/off (at 120bpm). Turn the GLIDE RATE knob up and down. Above 12:00, you should start to hear the VCA open up, and the sound of the oscillators will get louder. Make sure you are NOT playing a note, because we are setting the "OFF" voltage for the VCA, so we want the envelope to be off. Now turn the GLIDE RATE knob down slowly, just to the point at which the VCA is truly closed and you can't hear the oscillators at all anymore. This is the correct VCA Off threshold for your unit. Press the GLIDE On/Off switch to end the calibration.
Lastly... is this version stable? I don't know yet. It's the best improvement I could make, for now... my work will continue.
-- there is definitely no risk to your saved presets; they will persist unchanged by this firmware. Presets are saved on a separate memory chip in the hardware, so they are totally unaffected by firmware update.
Kind regards,
Amos
