Can voyager be made to start up with panel enabled default?
Posted: Thu Sep 22, 2005 5:18 pm
by magnet
Hi all-
I was getting a great sound setup last night, and forgot to save it. I realise that i can go into the menus and get the panel controls activated as is, (Ie: the sound I had built), but is there any way to have the unit power up as I had left it? Thanks so much-
magnet
wanting more and more sounds, come on V.3.0 and daughterboard.
Posted: Thu Sep 22, 2005 9:44 pm
by MC
Yes, there is a menu option to make the panel controls active, and one that recalls the last edited patch, even after power off.
Re: Can voyager be made to start up with panel enabled defau
Posted: Thu Sep 22, 2005 9:46 pm
by GregAE
magnet wrote:Hi all-
magnet
The Voyager should power up with the last sound in the EDIT buffer when the power was turned off (yours doesn't?).
In any case, to get back to the last edited sound, select EDIT function 1.2 "Recall Last Sound".
As for more sounds, you don't have to wait for Moog to release the OS3.0 DIY upgrade board. Go to SquareWave and check out the 100+ sounds already posted there:
http://launch.groups.yahoo.com/group/Squarewave/
Greg
magnet replies
Posted: Fri Sep 23, 2005 8:31 am
by magnet
hi-
No, My Voyager does not start up with what would have been in the buffer. It always starts up with what patch I last used. I was just hoping for a more convienient way to keep a "in developement" sound right on the panel, and accessable.
I also wish that the save sound/name sound was a bit more straight forward. I have had issues with that since day one. I am not a computer, or software novice, but "write/overwrite", or something makes more sense to me.
Another thing that I have noticed, and happens of its own accord, is that I sometimes 'arrow up' and the patch changes instantly. Other times I have to hit 'enter' after 'arrow up' to enable the patch sound. Happen to any of you?
I was hoping that there was a 'button press and power down' type of "lock" to have the unit power up always in panel mode. Thanks for any suggestions!
-magnet-
Posted: Fri Sep 23, 2005 9:09 am
by MarkM
If I have a patch that is in development, I just save it as INIT or whatever it started out as. Then I go back to it at my leisure. I find the saving of patches very intuitive on the V'ger. Much easier with less steps than my Waldorf Q rack or Ion.
Your last comments haven't happened to me. That sounds like a problem. Do you have the OS 2.5 update?
Posted: Fri Sep 23, 2005 9:54 am
by magnet
Hi-
Yes, well I guess I just need to establish a better starting point!
Yes, my unit came in March, v2.5.
Thanks for your comment.
-magnet-
Posted: Fri Sep 23, 2005 10:44 am
by Boeing 737-400
You have to go to the patch parameters. Just hit Panel, then the first option should be Quick Mode.
Posted: Fri Sep 23, 2005 11:56 am
by MarkM
I tested out whether or not the Voyager retains a patch in the buffer when it is turned off. I made a change to a patch, turned off my V'ger, unplugged it for about 20 seconds and then turned it on again. The patch was still in the buffer. I have an AE with OS 2.5.
