My Micro MOOG is giving me problems. Any Suggestions.
Posted: Thu Sep 08, 2005 12:02 pm
I have a Micro MOOG and apparently the Bypass switch isnt working properly. usually if you turn the switch of you can play notes and add sustain and release or what ever. then when you set it to ON, it holds the note for as long as the switch is set to on. Unfortunately my MicroMOOG only works when the bypass switch is set to the on setting, holding notes constantly.
Any suggestions on how to repair this?
thanks everybody.
thanks everybody.
